CLUTCH LOCKNUT!!!!!!!! 1995 zx9r
Old Sep 11, 2012 | 05:44 PM
NinjaRider24's Avatar
Angry CLUTCH LOCKNUT!!!!!!!! 1995 zx9r
i have opened my clutch in attempt to adjust the alternator chain tensioner. it sits behind the clutch components, so i have to remove them to preform the job. I am unable to remove the locknut holding the hub in place. So my question is, is the breaker bar not good enough, i used a 36mm socket with failure, only begining to strip the bolt. SO i dont know if im using the wrong tools, or if the bolt is loosened on a clockwise turn or counterclockwise.....please help. shame that aq stupid bolt is stopping my project.
Old Sep 11, 2012 | 06:58 PM
jeffzx9's Avatar
Welcome, Ninja. I'll check my manual.
Stay tuned....
Old Sep 12, 2012 | 03:09 AM
does anyone have an answer for me????????? i cant do anything until i find out. if you can help me out please do so. Thank You.
Old Sep 12, 2012 | 06:44 PM
jeffzx9's Avatar
Relax. My e-mail is down at work, so I'm scrambling to post wherever I can.
I checked the bible. No mention of the nut being reverse thread. Any way you can check the (hopefully) threads sticking out beyond the nut to see if they're reverse or right hand?
Old Sep 12, 2012 | 07:36 PM
unfortunately there were no threads visible. all are gobbled up in the locknuts throat.
Old Sep 30, 2012 | 11:26 PM
2fat2fly's Avatar
Have you fixed this yet? The easy way to remove the clutch hub nut is with in impact gun. 3/8" might do it but I always use a 1/2" impact. What year is your ZX9?
Old Oct 1, 2012 | 01:37 AM
The original post states it is a '95
The manual does not say squat on the threads. Just to remove them and to use a holder. I am thinking standard thread, even though you mentioned that you are unable to verify the thread direction.
Old Oct 1, 2012 | 01:19 PM
2fat2fly's Avatar
I have a 95 ZX9R engine sitting on my workbench right now. It's left-loose and right-tight. I use and impact with a 36mm socket and a gloved hand to pull the clutch hub nut as you see it in the picture.
Old Oct 2, 2012 | 02:52 PM
i bought an impact gun 1/2 drive. i got the impact socket, i am just waiting for the new lock nut to come in the mail before i remove this one. ill, update and let everyone know how it goes.
Old Oct 2, 2012 | 05:09 PM
2fat2fly's Avatar
If you have access to a welder you can take one of the old steels and weld a handle on it. Then use this in place of a gloved hand to hold the hub while loosening the nut.
