ZX7R Starting Problem
Old Mar 8, 2007 | 09:24 AM
suprakawigrl's Avatar
Default RE: ZX7R Starting Problem
I am gonna go check just a minute
Old Mar 8, 2007 | 09:41 AM
okay my hubby is sleeping. I found the starter but I can't see where I should use the hand tester. The manual is showing leads up by the junction box is this where I should test? Sorry I am still learning a lot everyday about this bike
Old Mar 8, 2007 | 09:48 AM
set the multimeter to voltage, slip the boot off of the starter or get the lead into the molex connection. You could take an amp draw while starting also. But only one wire of the starter if you did that.
Old Mar 8, 2007 | 09:52 AM
yes, you can test directly off of the "box",does not tell us the wire from the box to the starter, but that will work.
Old Mar 8, 2007 | 10:10 AM
okay when I test at the box and have the tester set to ACV on 10 the needle jumps all the over to the left...I hope I am doing this right?
Old Mar 8, 2007 | 10:18 AM
hahahaha, good thing you do not work with electricity SKG. PM me tomorrow and I will try to help out.
Old Mar 8, 2007 | 10:22 AM
no doubt...I will stick with the gear no electricity there...so should I delete my last post to save face around here or what?
Old Mar 10, 2007 | 03:32 AM
hahaha, I know my meters but not yours, so really do not know what the reference was. Its all good. Keep up the good work.
mikesimo
Jul 5, 2011 03:14 AM
Spohnmeister
Jun 23, 2009 03:42 AM
Spohnmeister
Jun 22, 2009 04:20 PM
96ninjazx7rtpaguy
Ninja ZX-7R
Nov 13, 2007 02:38 AM
gregburns
Ninja ZX-7R
Aug 17, 2007 02:39 AM
