front signal removal
Old Dec 30, 2007 | 02:51 PM
stone_sour09's Avatar
Default front signal removal
Does anyone know how to remove the stock front signals off an '01 ZX7?
Old Dec 31, 2007 | 10:13 PM
bigbrew's Avatar
Default RE: front signal removal
if there the same as my 97 which im sure they are, they are held in by just a rubber grommet (hope i spelled that right) they should just pop out of the hole, give them a little wiggle and pull gently. i took mine out and put in a pair of the flush mounts...looks alot better that way, mine is put away for the winterbut if you need a pic i would be more than happy to go out to the garage and uncover her and take a pic, let me know, its just a two wire system so you can check your positive wire with a testing light.
Old Jan 1, 2008 | 10:04 PM
Yah, I'm putting flush mounts on too. I started out trying to just pop one off, but I didn't wanna screw up or break anything. So, right now I have the air intakes off because they go right over top of the signals so I can get access to the signals in the inside of the fairings. I'll have to try what you suggested tomorrow or something and hopefully figure out something.
Old Jan 1, 2008 | 11:42 PM
according to my parts diagram, there is a 92015-1367 nut holding the gasket andbracket in place.
Old Jan 2, 2008 | 02:01 AM
bigbrew's Avatar
hmmmmm mine just popped out, no nut holding them in
Old Jan 2, 2008 | 02:07 AM
bigbrew's Avatar
drag if you look at that diagram a little closer the bolt holds the signal to that rubber fitting, does not acually bolt to the bike
Old Jan 2, 2008 | 03:49 AM
You are correct, but,,,any bolt that is flanged and is captive by a nutbetweenthe bodywork and theexterior part isactually a bolt on part. Am I wrong? But yes, I see a flanged area of the bracket with a nut attached for some odd reason then.
Old Jan 2, 2008 | 05:06 PM
bigbrew's Avatar
that bolt and flange just hold the rubber fitting to the signal, the signal just pops in that hole, maybe they built it like that so if you ever did go down the signal would just pop out and not tear your farring apart?? either way the farring is gonna get some sort of damage!.....stone if you have your ram air ducts off, reach down on the inside of the bodywork and squeeze the rubber fitting that comes through the bodywork and with your other hand gently pull out the signal, dont forget to disconnect the wires first, but leave yourself enough room to hook up your new ones, i just used a butt connector and wired up the new ones, i bought a pair of the flushmount off e bay
http://cgi.ebay.com/ebaymotors/Kawas...spagenameZWDVW
they worked pretty good because they tightened from the inside, plus my bike is black and they came in a smoke lens so they matched pretty good....hope this helps....bigbrew
shadymonukah
ZZR 600
Mar 31, 2008 12:03 PM
stone_sour09
Dec 30, 2007 02:50 PM
NightMayor
ZZR 600
Apr 12, 2006 08:35 PM
mr2turbo
Mar 18, 2006 09:15 PM
walight01
Feb 18, 2006 07:41 AM
