Chain hitting Swing-arm
Old Oct 14, 2007 | 12:07 AM
BlazingOrange's Avatar
Default Chain hitting Swing-arm
Hey guys, ijust boughta 03 zx7r and the chain had a lot of slack on it. I had it stretched and it's better now but if the chain bounces it still hits the swing-arm at the section where the swing-arm is closest to the chain. Should I be concerned? My first bike was shaft-drive so I'm not sure.
Thanks,
Old Oct 14, 2007 | 12:32 AM
jamest16748500's Avatar
Default RE: Chain hitting Swing-arm
how many miles are on the chain?
is it tracking straight?
make sure that chain is tight otherwise it could bind, slip or snap either way not pretty!
Old Oct 14, 2007 | 01:48 AM
Slapping under a load or while the ride is on the stand?
Old Oct 14, 2007 | 11:45 PM
the bike has 2200 miles on it. If I run over a bump I can hear it slapping the swing-arm. When it's on the stand i can move the chain up and it will hit the swing-arm where the chain is closet to it.
Old Oct 15, 2007 | 12:19 AM
tighten that chain up! also do you still have the stock chain gaurds? they should prevent the chain from slapping the swing arm. anyways just make sure your wheel is tracking straight b4 you are done otherwise you will have bad wear and traction on your rear tire, also your bike will want to dip in the opposite direction that the tire is off. ok there is my two cents.
Malves
Apr 6, 2011 08:46 PM
Flood_33
Mar 19, 2009 12:31 AM
gotrice
Oct 29, 2007 05:29 PM
MAD KAW
Aug 31, 2005 02:12 AM
eztalking
Aug 27, 2005 07:17 AM
