01' zx7r NO POWER
Old Feb 23, 2008 | 08:00 PM
ezrollin's Avatar
Default 01' zx7r NO POWER
I ran my engine till operating temp. Everything's Fine!
I'm pretty sure I had'nt touched anything electrical at all.
So I go to do my carb sync today, I hook up the calibration gauge wire to the #1 carb and try to start it.... NOTHING.
NO Indication of power whatsoever. Brand new batt! The oil light doesnt come on. The wires dont even spark when I hook up the batt! I try a car batt... NOTHING!
I hook up the charger to the batt 12v at 1-6amps.. nothing. So I jiggle all my connections around just to make sure nothings loose.. checked All fuses... Nothing! AGGH!
What should I start replacing? Relays? What should I start checking with the ohmmeter?
BTW It sucks walking to work when you're sick
thanks
Old Feb 24, 2008 | 01:16 AM
ezrollin's Avatar
Default RE: 01' zx7r NO POWER
I even tried to push start it by myself (not to actually get it to start but to get the mechanical parts inside to turn incase something was sticking like in the past). NO, this seems like a purely electrical problem.
no lights.
there was
no audible clicking... the batt and connections were cold to the physical touch. If All power has to go through the key-lock-cylinder.... How do you hot wire these things? I dont even wanna open my key-lock-cylinder up. I'll just turn it into a push-start.
Old Feb 24, 2008 | 03:17 AM
whitehendrix's Avatar
damn bro.. ya check the 30 A fuse on the solenoid? its the main power fuse for EVERYTHING..
jump the solenoid with a screwdriver (make sure you're in neutral!!) to make sure you got a ground and all..
i've never heard of a calibration wire for a sync setup tho...
Old Feb 24, 2008 | 04:21 PM
ezrollin's Avatar
ORIGINAL: whitehendrix
its the calibration hose (short one) that comes off the calibration Gauge when you have all hoses connected to the calibration gauge.
I'll post a pic for ya
edit: oops....everytime I said "calibration gauge" I meant "calibration manifold"
Old Feb 24, 2008 | 05:10 PM
ezrollin's Avatar
Old Feb 24, 2008 | 05:38 PM
ezrollin's Avatar
http://geocities.com/jonathan_abilene/starterrelay.jpg
In that pic, I put a screwdriver on that right sided (upper) lead and then connected it to the batt.. the starter turned over fine.
Old Feb 24, 2008 | 05:47 PM
ezrollin's Avatar
OMFG!! I turned the key for like the umpteenth million time and I saw it come on! I was so shocked! It HAS to be the key-lock-cylinder
but now I cant get it back on! LOL
Old Feb 24, 2008 | 05:58 PM
ezrollin's Avatar
so back to my original question.....
How do you Hot wire these things?
Put in a switch in place of the ignition key-cylinder.
Screw the security factor.. I just dont wanna be left stranded again!
If you need me to show proof of my title...FINE
If you want me to take a pic next to it to proove its mine.. FINE
thanks
Old Feb 24, 2008 | 07:58 PM
ezrollin's Avatar
please guys...
Dont make me break the key off in the ignition cylinder! LOL
I finished my carb synch and rode to work without a front end on at all. No lights, no fairings, no air intake baffles, nothing Haha
It feels like it runs sooo much better at lower rpms!
Here was my process:
idle at 1100
adjusted 1-2
adjusted 3-4
adjusted all
turn idle back to 1100
(cause engine was dying)
adjusted 1-2 again
cause they were off
The screws were SOOOO sensitive to being touched at all
Old Feb 24, 2008 | 11:13 PM
ezrollin's Avatar
only problem now is rear blinker blinks when its turned off and doesnt blink when it should be on LOL
