wtf... im hitting deadends...
Old Oct 3, 2007 | 04:20 PM
CRAZY's Avatar
Default RE: wtf... im hitting deadends...
what do u mean connecting rod? the rod that connects the piston to the crank?
i took the head to my local shop, there not gonna be able to get to it till next week
Old Oct 3, 2007 | 05:53 PM
speedracer138's Avatar
Yes, connecting rod. Check the bearings at the crank on the connecting rod. Pull and push on the rod up & down to see if it's loose. Het the head back and check it yourself like I suggested.
Old Oct 3, 2007 | 05:57 PM
Kohburn's Avatar
knock + low compression+ oil in exhaust+bottom end is solid to me says that you have a valve problem, possibly a bend valve, worn valve guide will cause the oil leak, any valve damage at all can cause it to not seat properly killing compression along with making a rapping noise when running.
could also be a stuck lifter not letting the valve close all the way.
Old Oct 3, 2007 | 11:14 PM
CRAZY's Avatar
ORIGINAL: speedracer138
theres no movement in them. ill get the head back tomorrow to check er out. im just not sure how to check the clearance. ill look in my manual. pain right in the nuts! lol
Old Oct 3, 2007 | 11:15 PM
CRAZY's Avatar
ORIGINAL: Kohburn
ill get the head back tomorrow and check that out!
Old Oct 4, 2007 | 03:43 AM
You can get plasti-gage at auto parts stores to check bearing clearances. Do you have metal/ aluminumparticles/ flakes/shavings in the oil?
Old Oct 4, 2007 | 03:40 PM
CRAZY's Avatar
no sir, no metal shavings/chunks... nothing. theres no play in the bearings either.
Old Oct 4, 2007 | 03:57 PM
BlackNinjaZX6R's Avatar
man this sucks sorry to hear man
Old Oct 4, 2007 | 06:59 PM
CRAZY's Avatar
yea man, your tellin me!!!
Old Oct 5, 2007 | 10:18 PM
How about the heads; did you check them out yet. Maybe you have a broken valve spring?
