valve adjustment BOOOOO!!!
Old May 16, 2008 | 06:30 AM
JokersSmile's Avatar
Default RE: valve adjustment BOOOOO!!!
I have a copy of the 03 service manual if you want it PM me your email address and i'll send it off..
Old May 16, 2008 | 02:45 PM
speedracer138's Avatar
I tried emailing a zip and rar filed manual but it wouldn't send.
Old May 16, 2008 | 04:48 PM
candylighting's Avatar
hey speed it worked!! jokersmile is gonna try to send me a copy of the full thing, if that doesnt work ill i need to know is the torque values for the cam bolts and whatever else i have to take off and when i put the cams back in i just line up the timing marks on the cam and make sure the crank is at tdc??
Old May 16, 2008 | 06:28 PM
http://www.thelinkup.com/shared/aci4skr3pao2
that link should have the service manual. Along with two others.
Old May 16, 2008 | 06:31 PM
thanks
Old May 22, 2008 | 02:16 PM
Crasher986's Avatar
You likely won't even have any out of spec, so won't even need to take off more than the valve cover. Seems like a lot of work, but it really sucks to take it to the mechanic and pay all that labor for him to change nothing! I did that a couple years ago with my Honda. Was 35,000+ miles and no adjustment needed. Pretty expensive for nothing, plus having to trailer it to and from the dealer.
Old May 22, 2008 | 03:40 PM
They charge for the labor involved to check them. It's kind of a pain to check the clearances. The Tank, Airbox, Valve & RH crankcover, coils, plugshas to come off anyway. Mine were out of tolerance (3 valves)when I first checked them and required adjustment. You need the narrow tapered feeler gauges to check these. I adjusted all to the tighter side of the allowable tolerance for more power. Just remember to loosen the cam chain tensioner and reset it (CRITICAL)before installation and check the camtiming (CRITICAL) a couple of times by rotating the engime by hand before closing everything up.
Old May 22, 2008 | 05:12 PM
Daves_636's Avatar
ORIGINAL: speedracer138
Recommended Valve Check/ Adjustment interval is 15,000 miles. Oill changes every 7,500 miles and spark plug clean & regap is every 4,000 miles!
oops! spark plug clean and gap at 4k? hmm...might be why i am getting a little hesitation on takeoff these days. thanks speed!
ZX12Rider
Sep 19, 2006 03:51 PM
kwninja88
Ninja 250R
Sep 5, 2006 04:49 AM
Notstock
Jun 23, 2006 01:01 AM
ZX_9r
Jun 16, 2006 04:08 AM
lemac
Apr 22, 2006 07:05 AM
