turn signal in headlight install
Old Apr 11, 2008 | 02:43 PM
wizzerdo's Avatar
Default turn signal in headlight install
I need a a little help. I put in led turn signals in my headlight last night... I tapped into the stock turn signal wiring and they work. I turn the key to the "ON" position and I turn on the blinker and they blink no problems. In the DIY there speedracer says to tap into the brown with silver dot wire out of the iginition wiring. If I do that, will it give me running lights? Is that brown and silver wire a constant and the green(LH) &gray(RH) the signal that tells blinks the turn signals? I would like the turn signals to stay on and flash when i want them to. Any insight would be appreciated. Is there a wiring diagram anywhere for an '03 636?
I did not start the engine when i did this b/c it was late at night...I don't remember if the side indicators stay on when the engine is on because I got the bike last week. (still not too familiar with it)
Hope someone can help me. Thanks.
Old Apr 11, 2008 | 04:48 PM
evil636's Avatar
Knee Dragging Pimp
Default RE: turn signal in headlight install
the indicators will turn on with just the key and continue on until you push in the button. im sure speed will chime in here but im running his kit with the euro lights and did not want to have running lights, only turn signals, so i took a light tester and found the wire that only flashes when the signal indicator is hit, i forget the color tho. but i believe you can have running lights that flash as well.
Old Apr 11, 2008 | 08:20 PM
kory636's Avatar
yes, if you tap into your ignition, it should give you running lights. its a constant 12v source only when the key is on. give it until late tonight, im sure he will respond to you.
Old Apr 14, 2008 | 11:19 PM
speedracer138's Avatar
There is a Brown wire withSilver Dots that goes between the frame & forks and is routed by the headlights. That is the power wire for the running lights that you need to T-Tap into.
Old Apr 15, 2008 | 12:47 AM
sup_uni's Avatar
speed i have a question about turn sigs to but i dont want to jack this guys thread
https://www.kawasakiforums.com/m_283.../tm.htm#284492
dan151
Aug 29, 2015 03:59 PM
ReaperFox
Jul 11, 2006 04:10 AM
taystyl
Apr 20, 2006 06:35 PM
MoserFtWayne
Mar 15, 2006 10:14 PM
walight01
Feb 18, 2006 07:41 AM
