help with LED turn signal install
im in the process of replacing all four stock turn signals on my 07' 250s with smaller LED ones. I wired the rear ones and everything works fine. When i plug in the front two and hit the turn signal button, they all seem to faintly illuminate (not flashing), and the indicator light on the dash doesn't come on.
any suggestions where the problem is?
LEDs offer almost NO resistance to get the flasher working. You need to add load resistors! They're pretty common items... should have come with the upgrade kit...
had a root around some other threads and i guess tomorrow im going to try unplugging my dash light and see if that solves anything as thats the only incandescent bulb left in the circuit, and probably pick up an LED flasher relay and some diodes and see if that is my fix
Because the LED is a "Diode" which only allows current to flow one way through it, what migh of happened is that putting your LED lights in has counted another diode. Try simply switching the wires (+ve and -ve) around at the indicators and see if that fixes it.
The lights will just flick quicker if you don't wire a resistor in line (or parallel) with the LED indicators - they will still work though.
