help with LED turn signal install
im in the process of replacing all four stock turn signals on my 07' 250s with smaller LED ones. I wired the rear ones and everything works fine. When i plug in the front two and hit the turn signal button, they all seem to faintly illuminate (not flashing), and the indicator light on the dash doesn't come on.
any suggestions where the problem is? |
LEDs offer almost NO resistance to get the flasher working. You need to add load resistors! They're pretty common items... should have come with the upgrade kit...
Originally Posted by rgoers
(Post 458205)
will i need to add a resistor for each of the turn signals?
I think one for each pair will do.
i read on another forum that changing the flasher relay to an electronic one from an autoparts store can solve the problem.
anybody else tried this? other suggestions? |
There's some old threads around here showing resister setup and also changing out the flasher unit for an LED conversion.
Originally Posted by IDRIDR
(Post 458218)
Because the LED is a "Diode" which only allows current to flow one way through it, what migh of happened is that putting your LED lights in has counted another diode. Try simply switching the wires (+ve and -ve) around at the indicators and see if that fixes it.
The lights will just flick quicker if you don't wire a resistor in line (or parallel) with the LED indicators - they will still work though. |
Originally Posted by Arctra
(Post 458231)
