Switching fairings? Need info please
Old Jul 8, 2007 | 07:34 PM
Dsmith50's Avatar
Default Switching fairings? Need info please
I have a 97 zx6r and was wondering if its possible to switch out the front upper for a newer front such as an 2000 or newer? Also on the tail could I doa similar swap?
Old Jul 8, 2007 | 07:39 PM
Default RE: Switching fairings? Need info please
Have you checked the part numbers in kawi's fiche' yet? To see if they will cross over?
Welcome to the forums
Old Jul 8, 2007 | 10:29 PM
Dsmith50's Avatar
I haven't checked is there any way you could get me a link for it?
Thanks for the welcome
Old Jul 8, 2007 | 10:45 PM
This is the place I use and is also cheaper than bikebandit. http://www.flatoutmotorcycles.com/
Old Jul 8, 2007 | 11:28 PM
grafhky52's Avatar
they are the same part numbers in kawi catalouge. i thought the headlights were different, but i guess not
Old Jul 8, 2007 | 11:32 PM
Dsmith50's Avatar
I checked the link and it shows both years of front fairings being #55028. Does that imply that they would interchange? Because it also has a 55028A for the 97 and a 55028A~C for the 2000.
The headlight on the 97 is a single and the 2000 has a double, but they may be shaped the same just different headlight placement.
Old Jul 8, 2007 | 11:34 PM
Looks like we are all learning something grafhky52!
Old Jul 8, 2007 | 11:45 PM
Normally, that last letters are a color code Dsmith50
Old Jul 8, 2007 | 11:50 PM
Dsmith50's Avatar
That's what I figured, if that is correct then all front fairings are compatable up through 2007 will fit. If that's true, I might as well make it look as new as possible(it's already immaculate, but I want a newer look).
Old Jul 8, 2007 | 11:56 PM
Mind you, I have not tried this so be thorough. But the numbers are matching. Just like the 05MC off of a 636 matches an 05 10r. Go figure!
edit: 04 and 05 10r
