Switching fairings? Need info please
This is the place I use and is also cheaper than bikebandit. http://www.flatoutmotorcycles.com/
I checked the link and it shows both years of front fairings being #55028. Does that imply that they would interchange? Because it also has a 55028A for the 97 and a 55028A~C for the 2000.
The headlight on the 97 is a single and the 2000 has a double, but they may be shaped the same just different headlight placement.
That's what I figured, if that is correct then all front fairings are compatable up through 2007 will fit. If that's true, I might as well make it look as new as possible(it's already immaculate, but I want a newer look).
Mind you, I have not tried this so be thorough. But the numbers are matching. Just like the 05MC off of a 636 matches an 05 10r. Go figure!
edit: 04 and 05 10r
edit: 04 and 05 10r
