Sprockets
Old Mar 12, 2006 | 03:41 AM
MacDaddy407's Avatar
Default RE: Sprockets
I ordered the sprocket set-up from sum of all parts for my 06 636. Stock is 15 front 43 rear, and what they say is optimum is 14 front and 45 rear. I only put on the rear sprocket and love it. I didnt want the rpms too high from changing the front also since I drive on the highway to work. You cant beat the price for both sprockets and a new R/K gold chain.
Old Mar 12, 2006 | 06:44 AM
ryninger's Avatar
You don't lose hardly any mileage dform changing the front as well. Esp on the highways when you RPM's dont get that high more often than not...
Old Mar 15, 2006 | 01:48 AM
murphmaster5's Avatar
so is 14/42 also optimum for the 03 RR
Old Mar 15, 2006 | 05:57 AM
Thats what sum of all parts says. I dont know if thats fact though.
Old Mar 15, 2006 | 07:46 AM
zx636's Avatar
what does this sprocket change of going to 14-45 do to the power range??? do you get more low end or more high end???
Old Mar 15, 2006 | 08:41 AM
ryninger's Avatar
def mind blowing low end over stock, and can still hit 155 top end...
Old Mar 15, 2006 | 09:41 AM
speedracer138's Avatar
That info from sum of all parts makes sense. That gearing will always keep you in a good powerband but if you're concerned about highway riding and mileage just change the front -1 and it would be like adding 3 in the back. That's what I did when racing on different tracks. It would make a difference low end and you'll keep your top end also. Plus, you won't have to buy a new chain unless your's is stretched out or you just want a new one.
Old Mar 15, 2006 | 09:49 AM
ryninger's Avatar
I did a -1/+2 and still get over 30mpg...
Old Mar 15, 2006 | 03:56 PM
Eklipse636's Avatar
to answer your Q, no i didnt have to take a link out of the chain to drop one in front. tire went back a little, but it worked out fine
Old Mar 15, 2006 | 04:00 PM
Notstock's Avatar
ORIGINAL: ryninger
I run the same and would not care about the mileage for what we are getting Want a high mileage bike buy a 250.
