Sprocket Questions
Old Sep 17, 2006 | 06:18 PM
Olympia636's Avatar
Default Sprocket Questions
Just a quick question because I can't find the answer anywhere. I have a 06 636. I (my shop) put on new sprockets about 1 month ago. -1 +2. The rear sprocket is aluminum and has already worn out. I would like to go with a steel sprocket 45 tooth but am having a bitch of a time finding one. Any ideas? Thanks!!!
Old Sep 17, 2006 | 06:35 PM
Notstock's Avatar
Default RE: Sprocket Questions
www.sprocketcenter.com
Call them and ask for brian he can help you over the phone and then ship the steel sprocket to you. I have had good dealings with him.
I have the same set up and use steel so as to not wear out so quickly, aluminum is for racing and not meant to last long just be light.
Old Sep 17, 2006 | 06:51 PM
Olympia636's Avatar
Right on dude...thanks alot!
Old Sep 17, 2006 | 07:16 PM
speedracer138's Avatar
ORIGINAL: Olympia636
You should replace the chain also because a stretched chain or worn sprocket will cause the chain or sprocket to wear out faster/ prematurely. CTSMoto has great deals on sprocket & chain kits or you can go with Power-Up kits. www.ctsmoto.com . Tell mike you're from the kawasakiforums.
Old Sep 17, 2006 | 07:22 PM
Olympia636's Avatar
Ok, i will check them out. I was planning on changing both sprockets and chain anyways. thanks!
Old Sep 18, 2006 | 10:49 PM
dcorlando's Avatar
How many miles does a sprocket and chain usually last? I don't ride my bike too particularly hard and I don't do wheelies. Thanks.
Old Sep 20, 2006 | 05:00 AM
Olympia636's Avatar
I would say you can get between 7-9k if you take care of them by adjusting the chain and making sure you keep the chain lubed up.
Old Sep 20, 2006 | 06:25 AM
evil636's Avatar
Knee Dragging Pimp
mine better go 50 thousand miles or im gonna be pissed. check out the sidewinder tri metal sprockets.
Old Sep 20, 2006 | 09:49 AM
Olympia636's Avatar
Those sidewinders are f-in sweet! Next sprocket I get will be one and prices are not that bad for something that will out last the damn bike!
klx250s_rider
Jun 12, 2008 01:49 AM
mudjunkie
Feb 21, 2008 09:12 PM
stainlessTT
Jun 8, 2006 01:05 AM
rkutzner
May 3, 2006 11:30 PM
