sliding the forks
I have had a lot of complaints when I ask how to slide the forks up, since I have an 06 and they are tapered but if anyone knows if it can be done easily just let me know. Thanks in advance.
Loosen the upper triple clamp,handlebar and lower triple clamppinch bolts (Do only the RH or LH side atone timetime). Then slide the upper fork tube up to a maximum of 10mm and tighten. Then do the other side. If you do both sides at the same time, the front end will drop all the way down and you WILL cause damage.
xyz1000rr
Dec 10, 2007 05:13 AM
Excidium28
Nov 1, 2007 02:28 AM
