Silly Oil Change Question
Old Mar 29, 2008 | 01:46 PM
Stubbz's Avatar
Default RE: Silly Oil Change Question
i have the exact same problem going on with my 03 636, i loosened the oil filter and a littleoozed out the bottom but not that muchand it stopped fairly quickly so i loosened it up some more and actually took the filter off while it was running and stillhad nothing coming out of the oil filter bolt hole. can it really have that much air in the system? it ran perfect when i put it away at the end of last season, and i changed the oil over winter but didn't run it after i just changed it and left it for the spring. any suggestions?
Old Mar 30, 2008 | 06:26 AM
zzrick's Avatar
MIne has never had this problem when I change the oil...strange.
Old Apr 1, 2008 | 06:16 PM
speedracer138's Avatar
That is very strange. Are you sure you put oil in??? I usually fill the oil filteras much as possible with oilbefore installing it. Maybe the oil pump orthe pressureswitchis bad.
Old Apr 1, 2008 | 06:47 PM
zzrick's Avatar
I never put oil in mine (the filter) and no probs, could it be something else?
cromag
Mar 23, 2010 04:21 AM
fnpaulie
Ninja 500R
21
Apr 22, 2008 02:31 PM
JETHRO980
Feb 20, 2007 11:36 PM
Red636guy
Apr 24, 2006 09:50 AM
gotrice
Jan 26, 2006 06:50 PM
