Shims
Shims
So i lowered my bike with lowering links and i need to raise it at least a half of inch for the perfect set i was wondering if anone knows anything about using shims on the rear shock? all help is appreciated
RE: Shims
The shims go between the top shock mount and the frame. You will see 1 fat stock aluminum washer/ spacer. You can use some autowheel alignment shims or order the set from Kawasaki.
