right rear set
yea her left fork is leaking but it isn't cause of the drop. the drop shattered her coolant resevoir. I figure the front left shock is going bad, but how do I test that and when is it really have to be replaced?
well on a fork, if theres fluid present, its leaking. probley need a reseal. youll need to remove the fork tubes and bring them to a suspension shop. the test is, if you see and feel fluid. its bad. and do both, not just 1 side. look to be spending about 200.00 to get it done. parts and fluid and labor for most shops. i think i had a set resealed for 180.00.
if it is leaking, dont ride the bike, you can take a slow leak and blow out all the fluid onto the front brakes/tire, it could bind up, cause her to get buck wild and go over the bars.
just fix it.
just fix it.
ORIGINAL: speedracer138
Fever, what kind of bike is it & does it have air caps on the forks?
i havent seen a set of forks like that since the 80's atc's
ORIGINAL: evil636
It was easy changing seals with the air forks. I'd drain them while still on the bike and put the drain screw back, remove the circlip retainer, tie a rag around the seal & fork leg and pump them to about 90 psi. POP; out come the seals. Then you just slide the tubes out of the triple clamps and slide on new ones. No need to dis-assamble the forks. It was easy; about 30 min to 1 hour from start to finish.
tedphips23
Feb 9, 2009 06:18 PM
kronus
Jun 27, 2008 01:27 AM
