power commander isntallation
Old Apr 17, 2006 | 02:46 AM
rawninja's Avatar
Default power commander isntallation
What's up guys! How many hours should it take to installed a power commander? Is it hard to do? A shop told me 2 hours of labor which seems a lot. If is not that hard to do i rather do it myself. Advice please!!
Old Apr 17, 2006 | 03:57 AM
gotrice's Avatar
Default RE: power commander isntallation
do it yourself.
halfhour to an hour no hard work at all
remove black plastic below handle bars /remove seat and lift tank (hard part is done)
place commander in trunk (as per pic in instuctions)
route cable along exhisting wiring harness (as per pic)
if u are sitting on your bike, the plugs go left to right 1 2 3 4
just unplug one at a time and do all 4 and the other plug and your done.
you will understand the instructions when you look at the instructions that come with your PC this is just them simplified any question pm me
Old Apr 17, 2006 | 04:04 AM
frrogger1's Avatar
ya it doesnt take to long to instal a pc....at most it should take the 2 hours and thats if you take your time
Old Apr 17, 2006 | 05:01 AM
rawninja's Avatar
Hey gotrice thanks for the help. I'll do it myself as soon as I get it (within the next five days).
Old Apr 17, 2006 | 05:16 AM
greenteam's Avatar
The hardest part is getting the connectors off of the injectors, guess I have big hands.
Don't forget to zero the throttle after the install, look it up on the CD that came with the PCIII. The throttle opening should read 0 degrees when your bike is hooked up to your computer. You can then also check what map came loaded with your Powercommander and make any changes necessory.
Mike
Old Apr 17, 2006 | 10:14 PM
txredneckmedic's Avatar
yeah mine were a pain to get off too. Big hands and small injectors powns me
Old Apr 18, 2006 | 08:54 AM
evor1's Avatar
use plyers or any other kind of tool you can use to grip the injectors. i used a wire crimper/stripper thing. pulled them off easy.
Old Apr 18, 2006 | 09:34 AM
joboy77's Avatar
I have big hands too, and like Evor1 said, I used pliers and it made it way easier.
arrowwhead
Jan 19, 2006 01:31 AM
arrowwhead
Jan 8, 2006 05:56 PM
eztalking
Sep 23, 2005 11:11 PM
fender780
Sep 7, 2005 06:36 AM
ntence
Apr 16, 2005 03:03 AM
