not running right
yesterday i was riding around with some friends and my FI light came on. we stoped to see what was going on. when i stiped ther was a hising sound from the gas cap when i opened it there was a lot of pressure built up we lifted the tank and the bleed tube was pinched we unpinched it and there was a little bit of fluid that came out. i coasted down most of the mountain. when we got to the bottem to the flat straight away i rolled on the throttle and the bike would not go over 7000 rpm, in all 6 gears. the dealer ship said that they cant get it in untill after the 18 of august. hopefuly the factory waranty will cover it. any sugestions would help. its a 06 636, compleetlysyock except for a intigrated tail light and euro turn signals. thanks for any help.
Just a guess but take out your air filter and see if it's soaked with fuel or oil. The breather/ vacuum tubes help route vapors back through the engine and if it was pinched, it had to go somewhere. Is it a Cali bike? They have a vapor canister that can get full of fuel if the lines get plugged/ pinched. Check all your other hoses & connections while you're at it. Also, remove and reinstall your EFI & ECM fuse to reset the computer.
