Not Running Hot Anymore
Old Jun 30, 2007 | 07:36 PM
rraiderr's Avatar
Default Not Running Hot Anymore
I have posted before about my 2007 running hot, not overheating but just running hotter than my previous bikes.
A few of you were experiencing the same issue while others were not. This lead me to do some research on the issue using my bike as the test subject and I now believe I have found the cause.
I started by doing all the checks as per the service manual only to discover the fan, thermostat and switch were all good.
The issue appears to be the cooling system needs to be bleed as it has air trapped in the system. I am not sure if it was the factory or dealer who filled the coolant but their was air in my system.
With motorcycles as opposed to cars air can get trapped in the system and not find it's way out without user intervention.
Prior to bleeding the system I would see temps while stopped in the 220-224 deg area now the bike does not exceed 219.
This is just what I found with my bike your issue may be very different.
Old Jul 1, 2007 | 05:04 AM
speedracer138's Avatar
Default RE: Not Running Hot Anymore
Good find! That's a commonly overlooked solution. Some car's (mostly Japanese) have bleeder screws just for air in the system. The air can compress and allows morespace for the water to boil casing verheating. You can probably drop the temps more with water wetter.
Old Jul 1, 2007 | 11:48 PM
alleakhatt636's Avatar
thanks for the info, im gonna check that saturday.
Old Jul 3, 2007 | 01:40 PM
EvilSmirk's Avatar
Good find and excellent point. However, how should I go aboutbleeding the cooling system on an '03 636?
Old Jul 3, 2007 | 03:11 PM
afboundguy's Avatar
I just did a coolant change on my 03 636 yesterday. Following the service manual with the bike off and radiator cap off tap and lightly squeeze the hoses. Then I started up the bike (with the bike being cool at first) and then let it run (with cap still off) and tap and squeeze the hoses again. The manual also told me to let the bike run with cap off untill the fan kicked on but I'm pretty sure that was to make sure the reserve tank was filled up. Hope this helps.
Old Jul 3, 2007 | 03:15 PM
rraiderr's Avatar
Some have a bleeder valve but my 07 does not.
The process is simple for no valve.
Have someone sit on the bike and keep it level. Remove the radiator cap. Start the bike. While it is coming up to temp tap and squeeze the radiator hoses on both side to dislodge any air bubbles.
Rock the bike side to side. Once the thermostat opens shut the bike off. Fill up the radiator so it pushes coolant out when you put the cap on so you know that you are not trapping any air in their.
Next make sure you overflow is between full and low when the bike is cold and you are done.
Do not get the coolant on your paint wrap a rag around the radiator cap.
jay_sco
Jul 29, 2008 10:16 PM
fnpaulie
Ninja 500R
18
May 30, 2008 03:02 AM
zx636skiv
Mar 24, 2007 04:22 AM
Forumsnow46
Oct 26, 2006 03:56 AM
kwninja88
Aug 22, 2006 12:59 PM
