New Exhaust... now Fuel injecter warning light??
Old Mar 30, 2006 | 09:31 PM
Ratkiller's Avatar
Default New Exhaust... now Fuel injecter warning light??
I just installed the dual GRP Thunder exhaust on my 06, zx6R. (by the way looks and sounds sick as hell) But when I took it around the block to test it out the Fuel Injector Warning light can on and when I was in neutral the idel was jumping up and down. Can some help me out?
Old Mar 30, 2006 | 09:53 PM
evil636's Avatar
Knee Dragging Pimp
Default RE: New Exhaust... now Fuel injecter warning light??
your going to die.
Old Mar 30, 2006 | 09:55 PM
evil636's Avatar
Knee Dragging Pimp
ok, just kidding, when you took off the vale system from the stock pipe did you put a servo stop on the servo motor under the seat ? that would be the only thing i can think of. did the pipe come with one ? il be back with some links to what im talking about.
Old Mar 30, 2006 | 09:57 PM
evil636's Avatar
Knee Dragging Pimp
here you go. you can get the same thing from 2 bros but it cost twice as much.
http://www.muzzys.com/EFIServoLimiter/index.html
Old Mar 30, 2006 | 10:04 PM
Ratkiller's Avatar
I knew it had to do with those 2 dam cables. So how does that thing install to the cables or does it get hooked directly to the servo some how?
Old Mar 30, 2006 | 10:09 PM
Ratkiller's Avatar
Here is a link to GRP's website the pic in the lower right hand corner is how they tell you the fix the cables. It's just a couple of link spacers crimped to the cables, they wraped in tape.
http://www.gpr.it/moto_scheda.php?id_moto=303
Old Mar 30, 2006 | 10:14 PM
evil636's Avatar
Knee Dragging Pimp
basically you remove the bolt thats holding the gear on and pull out the cables and the entire assembly and put the servo stop in place of the gear and bolt it up. done deal, youl hear it activate and a little flutter whitch is the servo motor and its done. simple as that.
Old Mar 30, 2006 | 10:15 PM
evil636's Avatar
Knee Dragging Pimp
ORIGINAL: Ratkiller
ummmmm yeah itll work but thats not how we roll
Old Mar 30, 2006 | 10:21 PM
Ratkiller's Avatar
Bam Italians!!!! Thanks Evil636. Quick and easy.
Old Mar 30, 2006 | 10:29 PM
evil636's Avatar
Knee Dragging Pimp
ORIGINAL: Ratkiller
rock on brother, ride safe
