Leo Vince Install Q's
Old Jan 25, 2008 | 02:39 PM
Default RE: Leo Vince Install Q's
it sounds cool tho bro[8D]
Old Jan 26, 2008 | 04:31 AM
speedracer138's Avatar
Sounds like the gears are stripped inside the servo. Did you hold the Servo Nut with a wrench or plierswhen you loosened & re-installedthe bolt? That stop is supposed to rotate, touch the cable mount, rotate the opposite direction, touch the cablemount and stop. Try flipping the stop over. If it doesn't work, you may need another servo.
Old Jan 30, 2008 | 12:40 PM
qbnlykwhoa's Avatar
What it ended up being is that it was traveling too far.. I put a zip tie around the black stoppers so the server has to travel less distance. Works like a charm. Seems when that servo fix was made it wasnt long enough...
Old Jan 30, 2008 | 02:33 PM
glad you figured it out! that pipe sounds good man.
Old Jan 30, 2008 | 04:01 PM
qbnlykwhoa's Avatar
Thanks man... yeah the pipe sounds awesome. The video does it no justice either... Super deep growl... I havent had a chance to ride it though, can wait to open her up..
Old Jan 30, 2008 | 10:39 PM
ninja636billy's Avatar
ORIGINAL: qbnlykwhoa
haha, you are in for a surprise then
Old Jan 31, 2008 | 01:11 PM
Have you done the ECU Jumper Mod yet? DO IT! You'll like it Do a before & after comparison but it will only affect wide open throttle/ Top End speed & power.
speedracer138
Dec 3, 2007 05:09 PM
Quad4_72
Oct 2, 2007 05:27 PM
speedracer138
Sep 4, 2007 05:32 AM
t56emac
Apr 17, 2007 02:57 AM
WAGS270
Feb 20, 2007 05:57 PM
