kleen mod
kleen mod
CAN you do the kleen air mod to a 03 zx6r, and if you can HOW DO YOU DO IT, and whats the best way to do it. i searched and i all i can find is 05-08 zx6r and im sure there setup is different.
RE: kleen mod
Same way as the 05-08 ZX6R's. Do a search; here's a couple I found.
https://www.kawasakiforums.com/m_270198/tm.htm
https://www.kawasakiforums.com/m_255229/tm.htm
RE: kleen mod
read all the linked posts, seems like a cool mod but also a good bit of work i.e. removing the tank
how easy is it to screw up your bike doing this? if all it takes is a bit of mechanical knowledge and the pics from the other site i might just do it at a buddys in a few days
i also need to do the jumper mod now that im getting into higher rpm more regularly
