jetting question.
Old Mar 21, 2006 | 01:25 AM
plyneon's Avatar
Default jetting question.
hey guys i recently put a yoshi rs3 bolt on, on my bike. and i wanted to get a k&n filter, but i read i need a power comander. i checked the website but they dont have them for my 2000 zx6r, now i gues i would have to rejet right? im not really in to the top seed or racing so thats about as far as my mods will go, but i dont want to lean out my engine. also i went to a local bike shop and they said it would be 140 for jets plus 120 for labor does that sound right? my choice is the kn but what about the uni filters has anyone tried them, any good? the guy asked me if i wanted the replacement uni or if i wanted idividuals? what would be better? i know lots of questions but i just want to be informed
Also is anyone here from the socal area im near palm springs.
Old Mar 21, 2006 | 01:54 AM
Notstock's Avatar
Default RE: jetting question.
Not a bad price for the work but I would not trust the dealership to wash my bike. JMO.
If you have a good relationship and trust your dealer not bad. The actual work is not that hard I have done it about 10 times and if it is your first time it will take about 3 hours give or take depending on your mechanical ability. You can order a jet kit form here http://www.dynojet.com/jetkits.php
I would call them if your not 100% sure of what you are ordering.
I have dealt with them on several occasions and they have great support.
Below is I picture of my kid helping me install new jets. He may be better than me.
I like the K&N my self but I have always used them, The BMC also comes highly recommended and I believe post better numbers than the K&N.
Good luck, Mike
[IMG]local://upfiles/346/F355606892B34988B93357707EFF6B9B.jpg[/IMG]
[IMG]local://upfiles/346/9E12D4EE78514926B69CB0EE7CF1CFEE.jpg[/IMG]
Old Mar 21, 2006 | 05:05 AM
evil636's Avatar
Knee Dragging Pimp
a replacement would be, well a replacement drop in filter like your stock one. individuals would be something like filter pods. when you run the pods your jetting is going to be way out of wack and will require you to make 3, 4, or 5 jetting changes to get it right. if your comfortable with doing it on your own, try sudco, i forget the web site but its a place in santa fe springs and they have every jet size for every carb imaginable, and by far the cheapest. dynojet would more then likley have a pack ready to go for your set up that will work.
Old Mar 21, 2006 | 09:39 AM
speedracer138's Avatar
Get the Dynojet jet kit for your bike. It's the best money you'll spend if you're rejetting. They've already done the research and have step by step instructions and tech support. The jet kit includes jets, needles, drill bits and recommended settings which are almost perfect. I HIGHLY recommend it.
Old Apr 21, 2007 | 04:07 AM
hicktown's Avatar
sorry to bump an old thread but i also need to rejet my bike. i think im fairly good at mechanical things how hard do you think it would be to rejet with a dynojet kit?
what exactly does this process do?
Old Apr 21, 2007 | 11:16 PM
Fairlyeasy if you're mechanically inclined.
Old Apr 22, 2007 | 04:40 AM
05ZX6R's Avatar
ORIGINAL: hicktown
By "rejetting" you will be getting jets with a larger opening so that it can flow more fuel at the same fuel pressure. The jets are in the carbs and feed the fuel into them. If you add some type of fabric hi-flow filter, then you will get more air and still the same amount of fuel, so without any adjustments to the carbs you will run leaner. By "rejetting" and putting larger jets, you are adding fuel and getting that air/fuel mixture back to the optimum 12 to 1 (+/-).
Old Apr 22, 2007 | 05:04 AM
hicktown's Avatar
good explanation i get it now.
redpillar
Dec 2, 2010 04:30 PM
mielamonster
KX250 & KX250F
Mar 26, 2008 11:38 PM
mielamonster
Jan 10, 2007 10:28 PM
Jacks Dad
Aug 16, 2006 11:34 PM
IchWarriorMkII
Jun 6, 2006 07:02 AM
