Installing Electropods
Old Jun 27, 2008 | 07:55 AM
mjtamar's Avatar
Default Installing Electropods
has anyone installed one of these kits??? i bought a set kinda on an impulse but it would look pretty sick and i have really no idea about how to start this task
thanx
-Buchi
Old Jun 27, 2008 | 02:33 PM
sup_uni's Avatar
Default RE: Installing Electropods
i have never heard of these, what are they do you have a picture of what they are or a web link?
Old Jun 27, 2008 | 06:32 PM
mikedrinfla's Avatar
I have them on my bike pretty easy to install.
Old Jun 27, 2008 | 06:35 PM
I installed mine with out taking the fairings off. Just figure out where you want to put the and do a mock set up. Have a friend help. Then make sure you clean where you are installing the lights. Stick them on and run your wires to a designated spot where you are puttinh the switch.
Old Jun 27, 2008 | 10:20 PM
768 Ryda's Avatar
i have a pair on bike i bought from cycle gear and pretty easy to install only take minutes, wires right up through a on off switch connected to the battery bro, i have the blue 1's and they look sick
Old Jun 28, 2008 | 12:45 AM
mjtamar's Avatar
ok so heres some more info to let you know that im still a lil clueless where is the battery and what is the best way to get to it lol???? i have a pretty good idea of where i want to put them but i want to make sure i have the switch in an easily accessible location. i like how you have yours set-up mike any hints or advice you can offer me?
Old Jun 28, 2008 | 04:28 AM
I have my switch mounted right next to the cluster. Then I have a secondary switch that turns on and off the front ones . That way I can ride with the side ones on. I took a AA baterry and hooked up to the light. That way you can put the light, with out attaching it, to see what it will look like. Like I said have someone help you so you can stand back and see what it will look like. Go to home depot and buy some commerical grade double sided tape it holds up alot better. The kit comes with bairly enouh tape. Buy the roll and you will be able to cover the base of the light alot better. Just make sure the area it clean...
Old Jun 28, 2008 | 04:31 AM
Old Jun 28, 2008 | 04:33 AM
giacoman
Mar 22, 2006 01:24 PM
Slate808
Feb 8, 2006 03:47 AM
arrowwhead
Jan 19, 2006 01:31 AM
eztalking
Sep 23, 2005 11:11 PM
eztalking
Sep 23, 2005 09:55 PM
