high beams
On the '06 both bulbs are the same brigthness but the low beam has a reflector covering the front of the bulb which blocks it and makes it less bright then the high beam side. Is there an easy way to take this off so I can go with the dual mod? Is there a lower watt bulb like a 35w that I can stick in the high beam side so it's not so bright?
glad i dont live in ca. around here in tn on the roads i ride you better run high beams all the time due to being able to see animals and stuff. but did make a small adj down on the high beams when i did the conversion.
highbeams in the day low beams at night i dont want to be blindning the people coming at me if ya know what i mean the purpose of running highbeams during the day is to make yourself more visible but at night the lowbeams are perfectly visible
