high beams
Old Jul 14, 2006 | 05:42 AM
lemac's Avatar
Default RE: high beams
ORIGINAL: 056r
highbeams in the day low beams at night i dont want to be blindning the people coming at me if ya know what i mean the purpose of running highbeams during the day is to make yourself more visible but at night the lowbeams are perfectly visible
Ditto....
Old Jul 14, 2006 | 06:36 AM
DanAllen636's Avatar
ORIGINAL: lemac
ORIGINAL: 056r
Ditto....
me too
Old Jul 14, 2006 | 09:08 AM
speedracer138's Avatar
You can remove the LH diffuser by crushing it and getting it out through the Bulb hole or intact through the harness grommet hole. The latter takes a bit of patience and finesse. As far as the stock H7 bulbs; they don't offer anything lower than 55 watts. You can adjust both of you stock headlight to the low beam position and use them in the hi-beam mode all the time. Maybe raise the lo-beam just a little and lower the hi-beam to match. The dual headlight mod uses a high & a low beam filament in each bulb. With the dual headlight mod on my bike both lights are on in the low beam and when the high beams are on, the low beams go off. You get a lot of light when needed with the mod.
Old Jul 14, 2006 | 09:07 PM
kaggriff's Avatar
great explaination speed. love your attention to detail. i did remove my low beam cover and lower my high beem and raised my low beam a touch. has worked great from day one. also used the silverstar bulbs love them. i would highly recommend them when doing a conversion.
Old Jul 14, 2006 | 09:57 PM
joro 600rr's Avatar
I'm runing on high beams all the time, day/night, maybe some times when there is cars in front of me, I go on low beams.
Better to be seen and make some people unhappy instead of be killed.
Old Jul 14, 2006 | 10:05 PM
kaggriff's Avatar
thats my thoughts on the matter. thats why i made a small adjustment to the light after the conversion. the guys here said they will ticket you in CA for that. gald i dont live there.
Old Jul 14, 2006 | 11:12 PM
You have to be careful. If you have your high beams on at night with oncoming traffic, you can blind them. They may see you but not see where they're going and end up running into you to avoid going off the road etc. I haven't had any problems with other drivers flashing their hi-beams since I did the dual headlight mod. I just like being able to see when leaning into turns now at night.
Old Jul 16, 2006 | 05:41 AM
racedoll's Avatar
If I'm riding alone at night I leave them on obviously if no one is coming at me, but if someone is then I leave them on for a second longer then switch off. I want to make sure they see me but that I don't blind them either. I have been in my car and been blinded by riders that don't turn them to low beam.
Old Jul 18, 2006 | 12:58 AM
kaggriff's Avatar
thanks for the advice. i do dim them a lot with on coming traffic. have to agree that it is much nicer at night if you have to go to low beam and find a corner.
Old Jul 18, 2006 | 01:00 AM
kaggriff's Avatar
guess thats what i get for saying all the time. all the time that it doesn't effect my safety with on coming traffic. lol
a16tony
Nov 10, 2008 04:28 AM
SDRRider
Feb 14, 2006 08:08 PM
NavKLX
Jan 26, 2006 08:42 AM
zixR
Jul 23, 2005 03:37 AM
swizzo
May 2, 2005 06:54 PM
