Help on ZX6RR (600 - K1-H) wheels!!
Old Jan 20, 2008 | 05:35 PM
SWB Ninja racer's Avatar
Default RE: Help on ZX6RR (600 - K1-H) wheels!!
im racing in streetstock.. so the forks have to be standard.. but internals can change...
but the rotors on the 2002 wheels are not only bigger in diameter but also smaller in width.. ie 4.5mm rather than my stock 5.5mm...
so using the spacers and bolts will make the discs fit in.. but then wud i have the problem of the brake pistons havin to far to travel (ie will they travel far enough) and or will this use more brake fluid up??
is there neway i could grab a contact number, as to maybe looking at buying some bolts/spacers off you??
Old Jan 21, 2008 | 05:51 PM
speedracer138's Avatar
The width of the 03-04 rotors should be 5mm but it won't make a difference or cause the pistons to come out.
cpr1
May 30, 2011 04:44 PM
benwiggins
Mar 21, 2010 03:08 PM
danniedavis
Jun 30, 2008 01:57 AM
BRIGHT
Aug 9, 2006 10:23 PM
BRIGHT
Apr 13, 2005 06:52 PM
