gas select and fuel overflow in carbs
Old Aug 13, 2007 | 07:20 PM
speedracer138's Avatar
Default RE: gas select and fuel overflow in carbs
You can try it to see if you like it and always go back to stock. Do you have a jetkit for the 36's? If not, get one; you'll love it!
Old Aug 14, 2007 | 01:13 AM
Kohburn's Avatar
i'm just trying to get the thing to be reliable right now.
i'm currently waiting for my new one-way starter gear to arrive... i was having starting trouble and discovered my gear was missing 6 teeth... was not a happy day.
Old Aug 19, 2007 | 01:27 PM
Kohburn's Avatar
haven't gotten to the carbs yet - but the petcock is rebuilt and working properly.
had a LOT of rust in the old tank so the float valve probably had a spec of rust keeping it open.
Old Aug 19, 2007 | 07:13 PM
personnally, I would keep the 36mm carbs and fine tune them. Keep that velocity up.
Old Aug 21, 2007 | 12:43 AM
Kohburn's Avatar
thats what i've decided to do - i really don't want to lose the fine throttle response for a little more potential top end
Old Aug 21, 2007 | 04:27 AM
Put an inline fuel filter when you put everything back together.
Old Aug 21, 2007 | 04:30 AM
Muraitic Acid in the tank will remove all the rust. Try a 50/50 acid/ water solution and slosh it in there. Rinse it quickly with water, drain andspray with WD40 to prevent flash rusting. Set it out in the sun to dry the remaining water completely.
Old Aug 21, 2007 | 10:50 AM
Kohburn's Avatar
it has an inline filter already
and i replaced the tank anyways since it had a big dent from previous owner.
bikebike
Aug 25, 2009 07:12 AM
eztalking
May 21, 2009 12:30 AM
eztalking
May 20, 2009 11:53 PM
Salem Greg
May 14, 2009 11:49 AM
chopitrakeit
Mar 24, 2006 08:03 PM
