ECU Jumper Mod works! Even with a Full Exhaust!
Old Oct 2, 2007 | 01:22 PM
speedracer138's Avatar
Default ECU Jumper Mod works! Even with a Full Exhaust!
My friend just dynoed his 636 endurance racebike. It has a Full Leo Vince Titanium Exhaust & K&N Filter. No Power Commander. I think I can get more power out of it with a PCIII or Race Kit ECU:
114 HP without the jumpermod;
119 HPWITH THE JUMPER MOD!
5additional HP just with a paperclip! Believe It!
Old Oct 2, 2007 | 02:17 PM
rocketrotary's Avatar
Default RE: UCU Jumper Mod works! Even with a Full Exhaust!
That's all fine and good if all you care about is peak hp, but what about the midrange?
Old Oct 2, 2007 | 03:00 PM
sweet!! but i thought you knew this already?
Old Oct 2, 2007 | 04:58 PM
768 Ryda's Avatar
was them no#'s at the crank or at the wheel
Old Oct 3, 2007 | 05:33 AM
Top end power only; yes I knew this already (just confirming again for the Non Believers), and the numbers were Rear Wheel HP.
Old Oct 3, 2007 | 10:43 AM
meanstrk's Avatar
If I am not mistaken, the jumper ONLY affects top end as per the ECU programming, right?
Are you able to post the dyno sheets?
Old Oct 3, 2007 | 02:12 PM
mikedrinfla's Avatar
Still waiting to do mine.
Old Oct 3, 2007 | 02:14 PM
Adam should I remap my PCIII after doing this or will it be ok with out doing the map?
Old Oct 3, 2007 | 05:47 PM
Just do it already; no mapping changes should berequired. This basically remover the EPA sound (decibel level) restriction and affect only top end. We didn't notice any changes in midrange. I'll see if I can get the dyno sheets & get themposted.
Old Oct 3, 2007 | 07:59 PM
Can I use a piece of copper wire?
