Condensation
Old Jun 1, 2010 | 09:41 AM
CDN ZX6r's Avatar
Question Condensation
My 2005 ZX6R's headlights keep getting condensation on the inside of the headlight lenses. How can I stop this from occurring?
Old Jun 1, 2010 | 07:51 PM
Prom's Avatar
Its a "Sealed" headlight which is meant to keep moisture out. If the seal is broken you might be able to find a kit to rebuild it, its alot cheaper than replacing it. In the mean time you can use a hair dryer to dry it out until you fix it.
Old Jun 2, 2010 | 03:11 AM
agreed, it is a "semi-sealed" system.
Is the dust cover in place and tight? The A of the headlight and the B of the dust cover are in alignment?
There is a seal break somewhere in your setup that you need to inspect.
good luck on the find
Old Jun 3, 2010 | 03:42 AM
CDN ZX6r's Avatar
Thanks, I'll check it out before work tomorrow and let you know what I find.
