Condensation
Its a "Sealed" headlight which is meant to keep moisture out. If the seal is broken you might be able to find a kit to rebuild it, its alot cheaper than replacing it. In the mean time you can use a hair dryer to dry it out until you fix it.
agreed, it is a "semi-sealed" system.
Is the dust cover in place and tight? The A of the headlight and the B of the dust cover are in alignment?
There is a seal break somewhere in your setup that you need to inspect.
good luck on the find
