Clutch problem after burn out?
Hey how's it going fellas? Today I did my first burn out yay! not only did i burn some tire, i think i burned my clutch trying to get the tire to slip.
After burning out I had to let the clutch almost all the way out for it to grab. I loosen it alot to get it where the sweet spot used to be. Does this mean my clutch is about to take a dump soon?
RE: Clutch problem after burn out?
enn it can mean alot of things cable is ready to shoot, take the oil fil plug out and if you smell the worst smell you ever smelt in your life when taking that off, then yes it your clutch, youll know you might ever throw up
It's an 05, and i didn't pull the oil cap off to smell it. But i did look at the oil and it still looks clean. I'll take it to work tommorow and see how it rides, hopefully my baby is ok[:@]. If it is the cable how do i check it to make sure it's fine?
i talked to a buddy of mine thats the head jack *** at a dealership in nc and we came to the realization that changing everyother spring and running the plates from a older zx6 was the ticket to getting the clutch to not fall off and actually hook up. i forget the year tho.
