Chain slipping?
Old Nov 4, 2008 | 01:39 PM
kwenui's Avatar
Default Chain slipping?
I've had a recent problem with my bike studdering during hard acceleration. I thought it was my chain, but I chekced my rear sprocket and re cleaned and lubed my chain and it looks fine.
I have just realized that the only time it will studder is in 2nd Gear at 10k rpm. or around 8k rpm if im going uphill. I've tried as hard as a could to get it to studder in any other gear but it won't. Only 2nd.
The reason I haven't checked my front sprocket is because it only happends in second gear so I was thinking it is probably transmission. I ride the clutch a lot also.
It is an loss of power for an instant about 3 times in a matter of 1 or 2 seconds as soon as I hit 10k. the engine sort of pulses.
Anything would help, I am gonna try to get a video (without killing myself) so u guys can hear it happen.
Old Nov 9, 2008 | 03:17 PM
speedracer138's Avatar
Sound like a bad clutch.
Old Nov 10, 2008 | 07:49 PM
768 Ryda's Avatar
x2 u can adjust the clutch cable to see if that will help
Old Nov 14, 2008 | 07:02 AM
whitehendrix's Avatar
eh..
how noisy is it? if the sprockets teeth are worn and the chain is loose, then its definitely the chain, but chances are it'll slip when leaving from a stop to if you stomped on it whilst leaving.
doublecheck the teeth and chain slack.. we can go from there..
a clutch will slip when the powerband is most beefy and when there is a good load on it, like if you were in 4th or 5th or 6th and sitting at 8-10krpm, then rolled on it hard, it'll slip then, or should, anyway.. or at least very close to that rev.. it shouldn't just do it in 2nd..
Old Nov 23, 2008 | 02:53 AM
mikes-si's Avatar
Could be your second gear?
taxpayer
Jul 27, 2018 04:12 AM
intense_05_636
Sep 21, 2007 03:40 PM
dmar
Feb 21, 2007 04:38 AM
SERGE
May 13, 2006 07:00 AM
99illinininja
Oct 9, 2005 05:04 AM
