brake bleeding is fun!
Old Jul 28, 2007 | 10:13 PM
markmeinteil's Avatar
Default RE: brake bleeding is fun!
ORIGINAL: onewheel
the best thing to do if you get air in the lines and bleading is not getting you a good lever feel.. Tap on the bango fittings as you are bleading
I know a lot of the time if there is air in the system it likes to hold up there.. vacing the system and pressure bleading sometimes doesnt get the air in that area
Yeah, I have tryed that too. I even removed the distribution block between the forks and tapped it with the handle of a screwdriver while turning it sideways. Nothing has worked so far. The M/C is also new. Does the same thing the old one did.
Old Jul 29, 2007 | 02:10 AM
onewheel's Avatar
calipers working right??
Old Jul 29, 2007 | 02:21 AM
Yup. Took them apart, made sure they weren't leaking. Also made sure the piston moved in and out which it did.
Actually, I was messing around with the bike today. After crack bleeding the banjo bolt up at the M/C a few times it has stiffened up a little. Still doesn't brake real well. But it does say I still have air somewhere.
Old Jul 29, 2007 | 12:59 PM
KevyzToy's Avatar
I didn't care for speed bleeders too much. They make it easy and not messy, but I just couldn't get good hard pressure on my lever with them.
Another tip after bleeding zip tie the brake lever closed to the handlebar. It will force air to the top of the resivor
Old Jul 30, 2007 | 03:52 AM
speedracer138's Avatar
The diaphragm is there so that when the fluid level goes down, it extends to keep the air in the resevoir to a minimum. And act as a sealto prevent brake fluid from leaking and keeps air & moisture out.
Old Jul 30, 2007 | 07:57 AM
Daves_636's Avatar
do you just leave the zip tie on over night?
ORIGINAL: KevyzToy
Old Jul 30, 2007 | 08:06 AM
Today I tried the trick where you use a long piece of tubing, tape the mid-section of tubing onto the fork about half way up, leave the bleeder screw open, and just start pumping. This method worked very well for me. The bike actually has stiffness in the lever now.
Old Jul 30, 2007 | 02:42 PM
i hate messing with brakes[:'(]
Old Jul 30, 2007 | 04:10 PM
1+ lol
Old Jul 30, 2007 | 04:20 PM
Kohburn's Avatar
ORIGINAL: markmeinteil
1+ lol
ROFLMAO
