Battery Removal
Old Feb 13, 2007 | 01:15 AM
SliverR6's Avatar
Default Battery Removal
Do you have to remove the tank to take the battery out? Was hoping to just pop the seat and take it out but it doesn't look like the case.Please give me some help. thanks
Old Feb 13, 2007 | 01:16 AM
BigO's Avatar
Default RE: Battery Removal
What year do you have? if it is an 05 then yes you will need to loosen the Tank.
Old Feb 13, 2007 | 01:17 AM
suprakawigrl's Avatar
I have heard on some bikes like the 6R you have to take the tank off, hopefully one of the experts will pop in to confirm that I have a 7R and I don't have to remove the tank.
SliverR6's Avatar
Ya it's an 05.
Old Feb 13, 2007 | 04:01 AM
Rains's Avatar
i think you need a second pair of hands to lift the tank in order to remove the battery. i've played around there and it doesn't look like there is any way to remove the battery without a second person holding the tank while the first person removes the battery... unless youremove the tank completely (including fuellines)... then i guess you only need 1 person....
either way, here's a tip - wrap the wrench you use to remove the battery terminal bolts with some kind of tape to prevent sparks ...
Old Feb 13, 2007 | 04:07 AM
Munchy's Avatar
You can take off all the bolts holding down the tank and lift it up and prop it off to the side, I had mine resting a bit on the frame (I put some folded paper between tank and frame so it didn't scratch), then you can easily get the battery out or to the terminals, whatever you need.
Another option is this:
http://www.kawiforums.com/forum/topi...TOPIC_ID=35012
(Seems to be blanked out... Sorry!)
Old Feb 13, 2007 | 08:39 AM
speedracer138's Avatar
I recommend taking the tank all the way off and setting is aside in a safe place. Make sure to disconnect all your connectors, fuel lines & vacuum lines. Hopefully it's not too full. As far as the battery; Take the negative terminal off first and you won't have any sparks and reinstall positive first.
Old Feb 13, 2007 | 01:48 PM
SliverR6's Avatar
Ya my tank is full. Thanks for the help
hercrigger
May 18, 2009 02:04 AM
sam
Dec 3, 2007 03:07 AM
wideopen
Dec 5, 2005 11:26 PM
randypape
Jul 15, 2005 03:34 AM
atcnga
Jun 30, 2005 06:18 PM
