anybody with lowering links
Old Jun 23, 2007 | 09:58 PM
afboundguy's Avatar
Default anybody with lowering links
if you have lowering links do you have to do anything about the kickstand? does it have to be adjusted?
Old Jun 23, 2007 | 10:35 PM
Live2Ride's Avatar
Default RE: anybody with lowering links
Most Likely, I lowered mine, the original kick stand made it virtually stand straight up wasn't comfortable with the way it stood. I cut an inch off then welded it then I decided to buy an adjustable kick stand. Hope this helps . good luck
Old Jun 24, 2007 | 01:50 AM
Isn't there an adjustable side stand? A friend of mine said that he has one on his lowered 10r. I did not get the name of it.
But yes, if you have the tools, you could cut and reweld, depending on the drop, you could grind some off of the fulcrum as well.
Old Jun 24, 2007 | 10:29 PM
shinobi636's Avatar
Mine is lowered, I had to get it cut, and rewelded. I am going to have it done again. The bike should lean at 30-35 degrees. Mine is at about 22, and it makes me nervous.
Old Jun 25, 2007 | 12:01 AM
afboundguy's Avatar
I was wondering cause I was putzing around 58cycle and noticed they had an adjustable stand for like $150 or some other ungodly high figure and they mentioned it's good for a lowered bike... I guess it's good to figure this out before I install the lowering links I have... Thanks for the advice all
Old Jul 2, 2007 | 03:06 AM
768 Ryda's Avatar
i have my 04 636 lowered 2 inches right now and took off a inch off the kick stand and welded the foot back on once i was thru, bike leans over flawless with no worries at all
Old Jul 2, 2007 | 09:50 PM
superninja600's Avatar
just lowered mine as well and cut an inch out and rewelded it back and its just fancy!
kdick91
Jun 25, 2014 09:00 PM
motodad
KX65
Apr 16, 2007 09:56 PM
klxstiffler
Jan 7, 2007 12:55 PM
kotacam
Oct 2, 2005 08:56 PM
cyclops
May 23, 2005 07:54 AM
