Lowered
Old Jun 26, 2007 | 12:59 AM
superninja600's Avatar
Default Lowered
I just put lowering links on my bike and i took it all theway down and it looked f*cking SEXY!! my problem is the resivour on the rear shock hits the swing arm so i had to bring it up some.. any suggestions on how to fix this problem so i can slam it back down?
Old Jun 26, 2007 | 01:47 PM
fastex500's Avatar
Default RE: Lowered
post some pics.
Old Jun 26, 2007 | 03:38 PM
firstninjabike's Avatar
Default RE: Lowered
+1
Old Jun 26, 2007 | 09:28 PM
speedracer138's Avatar
Default RE: Lowered
Did you lower the front also? This will affect your handling & ground clearance, so be prepared for that. Also, make sure that you have enough front tire to radiator and rear tire to undertail clearance when you bottom out. May want to add some preload to the front & rear suspension.
Old Jun 27, 2007 | 12:45 AM
Default RE: Lowered
This may not be related, but here goes. Different ride.
I know that a dropped 10r will chew off the fairing lower rivets on a speed bump.
Old Jul 2, 2007 | 03:04 AM
768 Ryda's Avatar
Default RE: Lowered
ORIGINAL: superninja600
do u have the 3 hole adjustable links, and what hole are u useing, i have mine set in the 2 hole from bottom and i have no problem at all
Old Jul 2, 2007 | 09:52 PM
Default RE: Lowered
ya its the 3 hole and i've got it in the 2nd one now, but i wanted it all the way down and thats where my problem is
Old Jul 3, 2007 | 01:16 AM
768 Ryda's Avatar
Default RE: Lowered
if yours are like mine, u put it in the 3 hole it will put that bad boy on the ground, lower it 4 inches to where it is at 2 inches lowered now in the 2nd hole
Bad Bear
Oct 26, 2006 01:49 PM
cartman
Oct 23, 2006 01:37 PM
zzr600racer
Oct 22, 2006 08:32 AM
gsims
Ninja 250R
Oct 7, 2006 05:04 AM
gsims
Ninja 250R
May 23, 2006 08:22 PM
