95 zx6r float heights
Old Sep 23, 2008 | 08:10 AM
zx6r_gav's Avatar
Default 95 zx6r float heights
g'day everyone,
well ive been having problems with my 6. over fueling after pipe being fitted. doesnt make sense but anyway. i set the float levels to 19mm from 16mm with the float needle touching but not compressed which is the lower limt in the specs.
factory pro say that the needle should be compressed when measuring the float height.
does anyone have any advice with this?
regards
gavin
Old Sep 23, 2008 | 06:39 PM
sup_uni's Avatar
to set float.
1. remove carbs
2. drain all fuel
3. place carb upside down and remove float bowl
4. set tabs on floats so that it is level with the carb
5. replace bowl and install floats
that is the easiest way and is recommended by most.
in order to fix the over fuel you need to re-jet the carbs not mess with the floats. i dont know what they were talking about
Old Sep 23, 2008 | 10:54 PM
zx6r_gav's Avatar
thanks for reply.
i have no problem adjusting float levels themselves but just thought its odd that its still over fuelling in 5500-6500 rpm range even with less then standard jetting 145 outside and 147.5 in middle. no needle shims and 19mm float heights
Old Sep 24, 2008 | 02:23 AM
sup_uni's Avatar
that is prolly your problem right there.
your pilot jet is about 100 over stock.
i couldent find the exact spec but that is way over i can almost gaurentee it
Old Sep 24, 2008 | 02:24 AM
sup_uni's Avatar
do those carbs have secondary jets? i wouldent see why they would. can you post a pic and i can see exactly what it looks like?
Old Sep 24, 2008 | 04:11 AM
zx6r_gav's Avatar
the mains are 145 and 147.5 the pilot is 35
its a cvk36 carb
Old Sep 24, 2008 | 04:00 PM
sup_uni's Avatar
when does it over fuel? low idle or hard hit?
what does the pipe manufacture recommend jetting it at after a pipe?
rejetting on a carb engine is like a powercommander on a fi engine. most of us have to do it after a pipe because it flows more and inturn makes the bike run richer
what is the color of the exhaust on the tip?
black=rich
chocolate/dark chocolate= perfect/ ish lol
light chocolate/white= lean
Old Sep 25, 2008 | 05:31 AM
Originally Posted by zx6r_gav
thanks for reply.
How do you know that your ride is "over fueling in the 5500-6500rpm range?" This a 1st gear hard on the throttle estimate?
Old Sep 29, 2008 | 01:59 AM
sup_uni's Avatar
you get his all figured out? whats going on with it?
Old Oct 8, 2008 | 09:35 AM
zx6r_gav's Avatar
nah its still same same, blows puffs of blacky brown smoke at those rpms
klx250s_rider
Apr 25, 2008 09:55 PM
YYY.GUY
Sep 24, 2006 05:31 AM
oldtimer
Jun 8, 2006 07:28 AM
heffay
Feb 10, 2006 01:52 AM
ZX_9r
500 LTD
Jan 19, 2006 03:04 AM
