2nd gear problems
Old Jun 4, 2007 | 05:04 PM
speedracer138's Avatar
Default RE: 2nd gear problems
+1^. That should be the first thing to check, then the shift lever position.
Old Jun 4, 2007 | 07:23 PM
Bluebeast's Avatar
that's some good info there 05zx6r
Old Jun 9, 2007 | 02:38 AM
gaijin's Avatar
Well I'm not sure about your year of bike, but the 05-06's do not have syncro's. In fact I have never seen syncro's in any bike. The gears simply have what are called dogs. They are lugs the protrude from the side of a gear, and lock into the gear next to them when slid by the shift fork. The fork rides on a rail. The fork is slid side to side via the shift drum. When you have a gear that pops out, it's one of two problems. Either the gear is not being slid far enough into the mating gear, or the dogs are damaged (rounded of usually). The drum RARELY fails. The shift forks are made out of aluminum on most bikes. The rest of the transmission components are made of steel/iron. The forks can be bent if a person is hard on the shifter. (Downshifting without a clutch is the worst!) The rails that the forks ride on are hardend steel. They are not very long (about 5 inches) so they are not prone to bending easily. There really is no way of knowing which item is damaged until she is opened up. (not for the faint of heart or the inexperienced.) But if you do decide to tackle it, do yourself a hugh favor...Buy a factory service manual. You can get them on CD now for as low as $10. I finished going through my transmission last night due to damaged dogs. (Previous owner) Hope this helps. And if anyone needs help with their 05-06 ZX6R, let me know.
Old Jun 9, 2007 | 03:52 AM
mikedrinfla's Avatar
Thanks for the advice bro.
Old Apr 29, 2021 | 07:31 AM
DionGriffey3728's Avatar
Default 05 zx6r
yes I need help my bike when I try to really get on it it slips and it’s only in second gear it’s feels like it the sprockets and chain buts it’s not can you tell me what this is and the guy I got the bike off of he put different clutches in it I can’t member what kind and he was running synthetic oil in the bike I have a new set of clutches I’m going to put in the bike and it tells me on it do not run synthetic oil I’m trying to figure this out can you help me I just got this bike
red
Jul 29, 2011 10:49 PM
kellen
Jun 12, 2008 01:45 PM
trey
Sep 11, 2006 05:21 AM
moparman48081
Sep 6, 2006 10:04 PM
taystyl
Jun 2, 2006 04:37 AM
