2007 kawasaki zzr has problems staying running?
Old Aug 4, 2013 | 11:51 AM
Plezm1st's Avatar
Default 2007 kawasaki zzr has problems staying running?
I bought a 2007 kawasaki ninja zzr 600 4 months ago it ran good for acouple weeks then coming home one day from work it hesitated a bit then just died down. It was low on gas so i thought it was that until it did it again. then i changed the plugs, fuel filter, air filter, oil and filter, gas in the tank, rode fine acouple times then did it again. I then put a new battery in and used sea foam the other day, ran good all day had it up to 102 then the next morning it did it again. now its setting in my garage, it seems to do it everytime im riding steady at 55-60? i dont know what else to check, i need help..
Old Aug 4, 2013 | 04:30 PM
Welcome to KF
Starting with the basics, there is a good chance that some sediment got caught in the carbs when you ran it low on fuel. Check the pre-screen on the fuel tap at the same time. http://www.ronayers.com/Fuel-Tank22-C70549.aspx
Sometimes sea foam will work as a treatment, but it works better as a preventative measure.
Old Aug 5, 2013 | 06:51 AM
Plezm1st's Avatar
Ok i will try that. I tried to start it again yesterday and with the choke on it tried but then shut down again. then i put the sea foam in the tank (just alil bit) again and it start right up. sounded alil rough. but i will try that today with the tank. thanks.
smartechzzr
ZZR 600
Jan 24, 2010 09:47 AM
jonnytalks
Ninja 500R
Sep 10, 2008 01:34 AM
dadalus23
Ninja 500R
May 17, 2008 03:36 AM
speedracer138
Sep 2, 2007 07:08 PM
dzerbe
800, 800 Classic & 800 Drifter
Jun 19, 2006 07:51 PM
