1995 ninja zx6r weird problem
Old Sep 30, 2006 | 06:04 AM
DONTOY's Avatar
Default RE: 1995 ninja zx6r weird problem
well folks finally found out what the trouble was by accident i tried the gas dryer ......no luck...i installed coils...no luck...i tried new coil wires...no luck.. but today as i was getting fuel i had my bike up on its centerstands as i alway do while fueling and after i went bak off the standa i started to go onto the street and the bike was acting like it was dying and the tack and temp guages were goiung wild so i took the bike home and traced all the electrical wires figuring something came loose and lo and behold the black wire from the alt to the battery was just barely touching in the quick connector sleeve next to the frome.. so i guess it was just shorting out and before once the fan kicked in the wirews barely touching will arc the current and caudse the bike to do the weird **** discribed, i reconnectec the wire and recrimped it tightly and wow it is like a new bike no problems at all...thank you jesus..... well folks thanks for the imput i really appricated it ......[IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
Old Sep 30, 2006 | 06:15 AM
speedracer138's Avatar
Yep, A loose or bad ground will cause all kinds of Gremlins in your bike. That should be one of the first things to check; a good battery, chassis and wire harness ground connections.
NinjaLover
Ninja 250R
Jun 28, 2010 10:59 AM
95zx6rGuy
May 22, 2010 09:00 PM
Savagekilla
Jan 8, 2009 05:03 PM
mason_rigby
Jun 19, 2006 09:28 AM
smokeater3194
Jul 25, 2005 08:25 PM
