Weird Fuel Screw Problem..
Old Jan 7, 2009 | 04:30 PM
Savagekilla's Avatar
Lightbulb Weird Fuel Screw Problem..
Hey Guys!! First of all Happy New Year!! I rode my Klx alot during December!! Had loads of fun
I also found a weird problem lol..
When I set my Fuel Screw by listening to the perfect idle sound (turn in A/F Until Idle dies then turn out till it dies again and set it in the middle of these two points) this method showed me a perfect setting at 1.75 turns. It idles perfect and starts up without applying the throttle and everything, but when I'm riding and I suddenly accelerate I had a bog, keep in mind this was at about 1.75 turns. It also tries to die when I accelerate when the bike is still (has a slight pull back effect) doesnt really die. So I thought f*** the idling crap I need to have crispy throttle when riding, so I kept on opening the Screw until the bog was almost non existent, and that point was at 2.5 turns open.
And now, it revs from idle to wot like a EFI machine, and it flies.. NO BOG.. But sometimes it wont start without throttle and even with throttle it wont start up as easy as it did at 1.75 turns on the air fuel screw.. And besides I changed the spark plug today. And the old plug was really black indicating a really really rich mixture.
My jetting is :
#120 DJ Main Jet
#35 Stock Pilot - Im having a bad feeling this is the culprit and I need to try the 38.. :S
Mods are in my signature Im thinking maybe the pilot isnt supplying enough fuel to compensate for all the air im letting in through the open air box and letting out through the aftermarket exhaust?
Thanks alot! And here are some new pics for ya'll!
Jamie
Old Jan 7, 2009 | 05:58 PM
oldphart's Avatar
Banned
Your probably rite about the pilot jet.I don't know about the Japanese spec bikes,if they had that smog stuff that everyone removes,anyway I removed mine and rejetted etc and everything was fine for a while then weird things kinda like your describing started happening.You know that vacuum port on the front of the carb well I had fitted a rubber plug which turned out to be of poor quality and it had developed a split which you could not see and was causing weird intermittent problems,something to look at anyway.
Old Jan 7, 2009 | 08:59 PM
horizonod's Avatar
Your plug was carboned up after riding with the screw out 2.5 turns or 1.75 turns?
I kept my pilot stock, put in a #128 main and adjusted the needle to the 3rd (middle) slot. My fuel screw was out 2.5 turns and the bike would start cold with no choke or throttle. I think starting without choke is a sign of being rich, isn't it? Anyway it would bog on me at higher RPMs or under a load so I started turning the screw in bit by bit. ( I sure wish I had spent that extra $25 on the fuel screw when I had the carb off!!). I can't be sure exactly because the driver I have to use to adjust it is one of those screwdrivers for eyeglasses cut off to about 2 inches long. It works, I just can't tell exactly how much the screw turns. I think it's at between 2 and
2.25 turns out and it runs pretty good.
Does anybody know where that front vac port goes?
Old Jan 8, 2009 | 12:18 AM
oldphart's Avatar
Banned
The hose from the front port went to the valve that sat on top of the valve cover it operated the smog crap(very technical term there).
Old Jan 8, 2009 | 12:50 AM
WestOzKLX's Avatar
My bike runs a tad rich but I love it that way. Great midrange and stormin' top end.
#38 pilot, #138 main jet.
Old Jan 8, 2009 | 01:32 AM
oldphart's Avatar
Banned
Default weird
Horizonod you can fit that mixture screw without taking the carb off I did and I'm a bit hamfisted take the cable or cables off depending on if you have fitted a vortex throttle or something similar maybe the cable bracket also unclip the idle screw from it's bracket(I think,poor memory) loosen the intake boot clamps and it turns enough to get at, just put a rag underneath in case the little washer falls out (mine didn't).
Old Jan 8, 2009 | 08:59 AM
My Vacum Ports are good
My plug carboned up after running at 2.5 turns. Tried playing with the Fuel Screw too.. The Top End with the #DJ120 is Much better than all the other Main Jets I'v tried..
It went to the smog valve, not a engine valve hehe.. (I thought Horizonod Will get confused as the valves are also just there).
My top end is really really really good! Do you think I should try the #38 Pilot?
Old Jan 8, 2009 | 12:04 PM
WestOzKLX's Avatar
? I went up to a #40 pilot then down to the #38 pilot. Seems about right now.
Old Jan 8, 2009 | 05:03 PM
Ok.. I think I will order a #40 and #38 and try em out!
Thanks dude!
NinjaLover
Ninja 250R
Jun 28, 2010 10:59 AM
95zx6rGuy
May 22, 2010 09:00 PM
DONTOY
Sep 30, 2006 06:15 AM
mario66
Jul 12, 2006 06:44 PM
ZX_9r
May 13, 2006 06:46 PM
