1986 ZX600r No Start NEED HELP!!
Old Jan 12, 2019 | 03:26 PM
Riddle6325's Avatar
Default 1986 ZX600r No Start NEED HELP!!
I have an 86 zx600r that will not start thought it was the starter relay so I replaced it and now soon as I turn key it makes relay buzz like I'm pushing starter button and will only stop if I either turn key off or unplug starter lock out switch on clutch lever. And help would be greatly appreciated also has charged battery
My Baby!!
Old Jan 13, 2019 | 09:27 PM
Riddle6325's Avatar
[QUOTE=Riddle6325;544778]I have an 86 zx600r that will not start thought it was the starter relay so I replaced it and now soon as I turn key it makes relay buzz like I'm pushing starter button and will only stop if I either turn key off or unplug starter lock out switch on clutch lever. And help would be greatly appreciated also has charged batte
I rescently pulled entire wire harness and checked all wire for shorts or broken wires and nothing grounds are good also another lil symptom is when I turn the key to on lights come on dim but if I turn a tiny bit more they get full power! Now front brake lever does not turn on brakes but foot brake does. I rescently installed new digital gauges would they be part of problem?
Old Jan 14, 2019 | 08:33 PM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
cssmgt
Aug 27, 2022 08:06 PM
Bergerman25
Jan 2, 2012 12:20 PM
kroad
Jul 14, 2010 11:35 PM
beebop
Jun 23, 2010 01:51 PM
A'szx00
Apr 30, 2010 02:37 AM
