1986 ZX600r No Start NEED HELP!!
I have an 86 zx600r that will not start thought it was the starter relay so I replaced it and now soon as I turn key it makes relay buzz like I'm pushing starter button and will only stop if I either turn key off or unplug starter lock out switch on clutch lever. And help would be greatly appreciated also has charged battery
https://cimg1.ibsrv.net/gimg/www.kaw...a88e6b94b0.jpg My Baby!! |
[QUOTE=Riddle6325;544778]I have an 86 zx600r that will not start thought it was the starter relay so I replaced it and now soon as I turn key it makes relay buzz like I'm pushing starter button and will only stop if I either turn key off or unplug starter lock out switch on clutch lever. And help would be greatly appreciated also has charged batte
I rescently pulled entire wire harness and checked all wire for shorts or broken wires and nothing grounds are good also another lil symptom is when I turn the key to on lights come on dim but if I turn a tiny bit more they get full power! Now front brake lever does not turn on brakes but foot brake does. I rescently installed new digital gauges would they be part of problem? |
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
