1986 ZX600r No Start NEED HELP!!
Old 01-12-2019, 03:26 PM
Riddle6325's Avatar
Default 1986 ZX600r No Start NEED HELP!!
I have an 86 zx600r that will not start thought it was the starter relay so I replaced it and now soon as I turn key it makes relay buzz like I'm pushing starter button and will only stop if I either turn key off or unplug starter lock out switch on clutch lever. And help would be greatly appreciated also has charged battery
My Baby!!
Old 01-13-2019, 09:27 PM
Riddle6325's Avatar
[QUOTE=Riddle6325;544778]I have an 86 zx600r that will not start thought it was the starter relay so I replaced it and now soon as I turn key it makes relay buzz like I'm pushing starter button and will only stop if I either turn key off or unplug starter lock out switch on clutch lever. And help would be greatly appreciated also has charged batte
I rescently pulled entire wire harness and checked all wire for shorts or broken wires and nothing grounds are good also another lil symptom is when I turn the key to on lights come on dim but if I turn a tiny bit more they get full power! Now front brake lever does not turn on brakes but foot brake does. I rescently installed new digital gauges would they be part of problem?
Old 01-14-2019, 08:33 PM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
cssmgt
08-27-2022 08:06 PM
Bergerman25
01-02-2012 12:20 PM
kroad
07-14-2010 11:35 PM
beebop
06-23-2010 01:51 PM
A'szx00
04-30-2010 02:37 AM
Quick Reply: 1986 ZX600r No Start NEED HELP!!
