06 636 Overheating
Old Apr 7, 2009 | 05:38 AM
Odimus's Avatar
find another dealer...you shouldn't be far from Lancaster/Palmdale...
Old Apr 8, 2009 | 01:32 AM
Originally Posted by zx6rowner
Hey guys I dont mean to be a pain but the major problem is not that its running hot, yeah that sucks too. But within the first mile im reaching temps of 210 and my bike stalls when downshifting to first gear and the higher the temp the more difficult to start if it restarts at all.
No worries. But check the obvious first again. Rad cap, flush the system, is the impeller good on your water pump, that kind of thing. 1 mile and 210 deg is abit much.
Old Apr 8, 2009 | 02:03 AM
j13's Avatar
j13
Our 07 6r has been gettin up to about 230 these last couple of days after sitting there for awhile at idle, something we're taking a look at. Typically it'll run between 210-220 in stop and go traffic. Which we figure to be normal, especially with the heat here in south texas.
Old Apr 8, 2009 | 07:50 PM
zx6rowner's Avatar
The system has been flushed. Everything works fine, but the heat still rises at an unreal pace and the bike stalls when I downshift into first.
Im going to lift the tank this week and check the vent hoses see if they are crimped but I cant think of anything else.
Old Apr 9, 2009 | 01:15 PM
candylighting's Avatar
if the water pump is bad it will get hot super quick, also if the thermostat is stuck it will heat up quick, if these bikes even have something like that. also if the radiator is clogged or block it will heat up super quick.
Old Apr 12, 2009 | 11:08 PM
speedracer138's Avatar
Did you bleed the system? There is a bleed fitting behind the head on the thermostat housing. Make sure all the air is bled out. If it still does it, the your thermostat is stuck closed. Replace it.
DragonZ
Dec 19, 2006 09:11 AM
DragonZ
Ninja ZX-1100R
Nov 26, 2006 09:50 AM
silverado
Sep 25, 2006 05:59 AM
tbav8or
Jul 29, 2006 04:53 PM
Gerg
Jun 26, 2005 03:41 AM
