04 kawasaki race cam ?
Old Feb 10, 2006 | 04:41 PM
thecount's Avatar
Default 04 kawasaki race cam ?
hi im new to the site and want to know if anyone has put a cam in thier 636.i already ordered the cam from kawasaki and its only the intake cam.they also said i have to buy intake valve springs just wondering if its worth it or not.and do i have to tka the motor out?any info will be great.thanks
Old Feb 11, 2006 | 11:52 PM
lemac's Avatar
Default RE: 04 kawasaki race cam ?
Never did cams in a bike before, but in a car I know that new springs are in need to compensate for the increased lift and duration of the new cam. Labor wise on a bike I don't know I've never done it before. I think you might be able to get away with changing the cams with motor in bike, but if you change the springs make sure the cylinder you'r working on is at -tdc- and the remove the sparkplug and fill the cylinder with air via compresor and leakdown adapter... so you dont drop a valve while you r changing springs... BTW welcome to the forum and good luck in you endeavor to more power...
Old Feb 12, 2006 | 12:06 AM
Cam work can be done with the engine in the bike. lemac is correct in not dropping valves. I am not sure on this kawi cam and spring combo, and also make sure that the springs are not too much stronger. Otherwise you could risk popped heads on the valves due to an over aggressive spring pressure. But this is where you need to do some more homework on with your provider in order to feel all nice and comfy with this endeavor. Good luck.
TTR174
Mar 15, 2016 10:03 PM
katryder1
Apr 4, 2009 04:53 AM
Droz32
Nov 1, 2007 11:48 PM
speedracer138
Aug 13, 2007 05:49 PM
speedracer138
Jul 22, 2006 06:48 AM
