dead zed
Old Apr 13, 2008 | 11:33 PM
cab43's Avatar
Default dead zed
Hi all,
just done some minor work on my 91 zx1100 (coolant pipe from head to pump and new gear selector rod) went to start her when i was finished and shes not firing and today loud clicking from ignition relay.
are ther any common faults i should be checking out or is it just a process of ellimination.
any advice would be much appreciated.
cheers.
Paul
Old Apr 14, 2008 | 05:56 AM
whitehendrix's Avatar
Default RE: dead zed
sounds like simple voltage drop problem..
meter your batter.. make sure you got 12-14 volts there..
does the bike roll freely in neutral?
just to make sure that its actually there.. ya know.. since you were playin with a tranny component.. just ensure its not actually in gear, and the neutral switch is lying to you..
no common faults to my knowledge.. (well, watch the abuse on second gear..)
good luck, keep us posted, and welcome to KF!!
Old Apr 15, 2008 | 05:37 PM
cab43's Avatar
cheers, still not sure whats going on with it.ive got a spark and the fuel pump seems to be working but nothing.
if the ignition relay was u/s would this effect anything other than the starter motor?
Thanks.
Paul.
Old Apr 15, 2008 | 05:39 PM
cab43's Avatar
sorry , and by voltage drop do you meen it could be shorting out somewhere?
paul.
Old Apr 15, 2008 | 05:55 PM
Kohburn's Avatar
voltage drop can be caused my bad battery, undercharged battery, poor grounding, corroded connections, etc
Old Apr 16, 2008 | 06:33 PM
cab43's Avatar
just had another play with it, battery ok.
but i shook the bike from side to side while pressing the starter and she fired up and ran for a moment then died again
Old Apr 18, 2008 | 06:59 PM
cab43's Avatar
ok, fitted new spark plugs today and got her fired up.
everything looked ok until i tried to give her more throttle and she died again.
sound familiar to anybody?
Old Apr 19, 2008 | 08:36 PM
cab43's Avatar
SORTED!!!
Turns out the fuel tank was leaking, petrol was getting out but more importantly water was getting in.
Drained the carbs and bobs your uncle.
must of been on her way for a while cos shes pulling like a train now
sup_uni
Z1000
May 22, 2009 02:37 PM
flowrider
Z1000
Jul 7, 2007 10:27 PM
pudkeith666
Z1000
Jul 2, 2007 06:37 AM
Nobrakes
Jun 28, 2006 07:00 PM
cdm369
May 16, 2006 04:09 AM
